Separating this question from the converter thread.
C4, C6, AOD, 4R/5R/6R?
Right on. 2000hp through a C6. Try that with a stock case 'glide or 400. He runs stock case, pump, gear set and servo. His own billet drum(800.00), valve body(750.00) and good clutches and rollarized.Frank Merkl FTW!!
I'm hoping he or someone else can figure out the 2 speed, 2nd gear trans brake for the C6.I'm building one now(having it built) using Merkyl's parts and the now extinct Trans-King gearset(1st is 2.26). Planning to run 7's with it in a blown application. The technology is slowly coming to the C6's because of Frank M and a couple of others. If these catch on there will be no reason to run a non Ford tranny unless you simply prefer a 2 speed.
In 1000 runs I have NEVER had a problem with the forward clutches except once. When that happened, we found out the ball check valve in the pressure piston was leaking and bleeding off pressure. Replaced the piston and I think I'm still using the same clutches 200-300+ runs later.Right on Randy. Burnt the forward clutches in my AOD after 5 passes. Going to FB so he can sort it out. C6 back in. Can't hurt it.
I'll have my car at the NMRA race in a week. Running dial in for dollars on Friday. Grudge Saturday night and B2 and/or B3 on Sunday. You coming up?
Shouldn't he a problem. I got my first of his VB from a guy who was making near 1000hp with a Clevor and he was in the 8-9k range..
What kind of RPM will a C6 with Merkl's drum be dependable at? I currently run a C4 but plan on upgrading down the road. Shift points will probably be around 8800 to 9000. Decent amount of HP but very low torque motor (turbo 4 cyl.) and I need 3 gears.
Merkyl has run his door car in the 7's.Anyone know what the fastest pass with a Ford trans is?
What transmission is in the car in your avatar then a C-4?X1000
Joel told us years ago that the fastest transmission on the planet is a C4. Then he proved it to us.
C-6 would weigh more than your engine. Are you breaking the C-4?.
Ford guy till I die..... TH400 or Glide.
To really "build" a TH400 for serious duty, you will be starting off with an aftermarket case ($$), then billet everything inside.
This makes a full race TH400 cost substancially more than the comparable C6.
The C6 case is STRONG!! and its reinforced in critical areas.
Everything in the C6 is large....so in stock form, they do have a lot of parasitic drag, but thanks to Merkle and Dynamic and others, the lightweight drums and complete geartrain assemblies rival anything thats found inside a TH400 race trans.
This highly technical post of yours is too much to take!!Yeah, thats why so many people use the C6 instead of the th400....... NOT.
