Upside down shock?
12K views 11 replies 8 participants last post by  ty_ty13
Is there an advantage to mounting shocks upside down? I know the afco site says it's for less unsprung weight, but is there true performance reason one would do this? I should be getting my da Vikings in a few days and was just curious if I should try them that way. Also , would there be any ill tuning issues?
#2 ·
Less unsprung weight equals less weight that the shock has to control.....THAT IS the performance advantage. Not all shocks as far as I know can be mounted upsidedown so better check with Viking. Only downside I can see is getting at the knobs.
#3 ·
^^^^^This
I use AFCO shocks and they are designed to be mounted upside down so the knobs are positioned for easy access.
#9 ·
WHY MOUNT A SHOCK UPSIDE DOWN?
AFCO shocks can be mounted upside down to reduce unsprung weight which is anything not bolted solid to the chassis. If the race car were lifted by the main rollcage, anything that would hang down would constitute unsprung weight. Examples would be the wheels and tires, the axle housing, struts, and shocks. Reduction in unsprung weight can promote quicker ET's and extend the life of the race car's components. Also, the reduction of unsprung weight should reduce the chance of wheel hop or tire shake. The momentum of the axle housing (less is good here) will determine whether the tire becomes disturbed and loses traction. Decreasing the mass will give the shock a better chance to control the axle housing during separation, will allow the use of softer shock settings, and will produce quicker runs.
