PPH per HP
1 reading
3.9K views 7 replies 4 participants last post by  juiced coupe 78
Maybe I'm blind and missed it, but does anybody have a chart that shows the approximate PPH of nitrous used per HP setting? For example, 100 PPH = XX hp? I just want it for a reference to keep in my trailer...I weigh the bottles before and after a pass, and change every pass, but just want something to refer back to for usage...Also to help me estimate how much I'm going to go through at a given event.....
#2 ·
Simple question, but the correct answer will likely vary from engine to engine / n20 system to n20 system / tuner to tuner. That said, at a PPH level of 4157, on 3 "healthy" n20 systems (1 single noid fogger 36n27f, 1 dual noid spraybar 37n27f, & 1 dual noid fogger 41n30f) tuned professionally by Steve Johnson, on a Fulton 718 (4.61 x 5.375) indicates HP of 1186. FWIW, that equates to .285 HP for each PPH.
Hope this helps you.
#4 ·
#6 ·
Cool, thanks! Not real concerned about getting super accurate, I was just wanting a way to better estimate how much I'll be using per pass based on tune up. It's more for a reference than anything else, and to determine how much I need to bring!!!
#7 ·
Juiced, I think you meant to say 4 PPH per HP. Or, .25 HP Per PPH. Total HP = Total PPH divided by 4...roughly.
