New Borg Waner S400SX-E Range
18K views 72 replies 23 participants last post by  [20B]
I have noticed on an old SEMA 2015 video that a sales rep for Borg Warner was talking about their 'new' S400SX-E range of turbos. Particularly he spoke of the 10 blade 88mm compressor with T6 exhaust housing - made reference of a new 1.15 A/R housing too.
Does anyone here have some info on when these might be released? Anyone know which other models will be released in both T4 and T6?
I am wanting to buy a new turbo soon and was looking at their 80mm billet t4 model - now I have just found out about their new range - might as well wait!
Any info would be great!
Thanks :D
#5 ·
such as..????
i just received my 82mm billet s400 a few weeks ago from dr turbo. im not sure what is needed that is not already posted in this section.
if there is something your concerned with id give forcedinductions a call or others to answer more specific questions you have.
#7 ·
Yea it's a 10 blade compressor wheel on a 96mm turbine wheel. Authentic BW compressor wheel. Not an aftermarket CW.
#19 ·
Here is the information I found posted by work turbo on FB:
S400SX-E 88/96 Supercore (less turbine housing): Brand new Forged Milled Wheel Technology 88mm compressor wheel with "10+0" full compressor blades, latest high performance compressor cover, 360° thrust, 96/88mm turbine wheel. Fits all existing turbine housings for the 96mm turbine wheel. Rated at ~1575 HP.
S400SX-E 80/96 Supercore (less turbine housing): Brand new Forged Milled Wheel Technology 80mm comrpessor wheel with "10+0" full compressor blades, latest high performance compressor cover, 360° thrust bearing, Fits all existing turbine housings for the 96mm turbine wheel. Rated at ~1350 HP
S400SX-E 76/96 Supercore (less turbine housing): Brand new Forged Milled 76mm compressor wheel with "10+0" full compressor blades, 96/88mm turbine wheel, latest high performance compressor housing, 360° thrust bearing, fits all existing turbine housings for 96/88 turbine wheel, Rated at ~1250HP, Also available with the 87/81mm turbine wheel, rated at ~1200HP,
S500SX-E 88mm Supercore (less turbine housing), latest Forged Milled Wheel compressor technology with "10+0" full compressor blades, 360° thrust bearing, fits all existing S500SX turbine housings, Rated to ~ 1625 HP.
S500SX-E 94mm Supercore (less turbine housing), latest Forged Milled Wheel compressor technology with "10+0" full compressor blades, 360° thrust bearing, fits all existing S500SX turbine housings, Rated to ~ 1875 HP.
T6 1.15 A/R S400SX turbine housings to fit 96/88mm turbine wheel. Housings feature "VTF" or "twin scroll" inlets common to all S400SX T6 current designs.
T6 1.58 A/R S400SX turbine housings to fit 96/88mm turbine wheel. Housings feature "VTF" or "twin scroll" inlets common to all S400SX T6 current designs.
#22 ·
Has anyone talked to someone in the know about the Gamma Ti turbine wheels, availability, sizes?? This could be a real game changer allowing quicker acceleration leading to much higher shaft speeds earlier in the run due to the considerable reduction in rotating mass.
#29 ·
Subing to this as I too am ready to buy one on the t4 10 blade BW for my 6.0. Jose, if you have pricing with one of your covers pm me a price. Thx
#45 ·
They are available in 96mm 1.30AR, I am running twin 80mm with this setup on 402cuin 18* SBC. They spool great and back pressure is 1:1 or better to 35psi.
#51 ·
Possibly 3000hp based on BW's catalog eatimate of ~1500hp each.
#61 ·
Agreed. BW is saying to us that the compressor is 160lbs/min just like the 88mm GTX.
I doubt the turbine is up to the task like the GT55 is.
#63 ·
I have been running a pair of the new 10 blade 72/87 T4 turbos on my 441" Lsx 275 radial car. This past weekend we went over 159 mph to the 1/8 on 27 psi multiple times in shitty 95* day conditions. Problem is I don't think they will make much more boost. I am going to log back pressure next time out and see how bad it is but I added a fair bit of co2 on top of the gate and didn't really see any more boost.
#65 ·
The one I was referring to is on a car sponsored by BW. I am the engine tuner.
