Wiring a 110 outlet off a 220 leg?
55K views 27 replies 21 participants last post by  JJB
I assume this can be done but I'm having a brain fart trying to picture it in my mind. I googled it but I can't seem to find it. Anyone??
#2 ·
you only use one of the legs for hot. each legg on a 220 outlet is hot with 110. so use the black for hot, the white for neutral and green or copper for the ground. if you are taking it off an outlet make a pigtail and attach it with a wire nut. good luck.
#5 ·
OK, this is a 3 wire 220. It has a black, white and green wire. It's basically like the drawing below but the colors are different. Black and White are hot, green is neutral.
This is what I'm working with.
This is what I would like to do. Break the wires at the wire nuts and wire into the switch as a disconnect but then run a leg to the 110 outlet.
#11 ·
I got it! A buddy of mine I saw at lunch told me what to do. This is for my 220 single phase lathe and I wanted a disconnect between the twist-lok plug and the Drum Switch. I also just wanted a 110 outlet for anything miscellaneous I just need an outlet for. It works perfect.
#13 ·
understand this when looking at your panel you will have two main feeders comming into that box, those are your two feed legs they will feed each side of your panel...you need a 110v source from each leg going to your outlet...if you take 2 110v sorces from the same leg your device your are powering will not work...there will only be 110v at that outlet until you draw a feed from each side of the feeders in your panel....
#20 ·
It will not have the capability to trip in the event of an issue with what is plugged in.
Used to do that when arriving at a job site and all the temp plugs are in use and many cords already tapped in on multi-taps.
Made an adaptor that plugged into the 240 volt plug, it really used to confuse the carpenters, they would ask where that 240 volt worm drive came from. And the 240 volt hot glue gun and fans and sanders. Never had an issue arise but it could happen with a short or something.
This post has been deleted
#21 · (Edited)
Nevermind
