Hi Guys,
I need help.............
I'm running a block fully sealed and only have water through the head..
My old car ran a radiator with a thermo fan and a Davies Craig EWP80 and on idle the water temp would stay on 155f the a/f was 4.5,if I leaned on it the water would go up fast......
The problem now is I wanted to get away from running a radiator and I made a round 6" cylinder approx 8" deep and with an electric pump,thought I could pump water through that and keep the engine cool that way but its not working,the water lines are all the same as before but now the temp goes to 190f and will still go higher......
Is the way Im doing this a good idea,I really would like to somehow keep the engine temp stable and be able to idle and not worry about the temps......
With a radiator the temp on the startline was 155f and across the line was 168f,so Im thinking the tune is ok too..........
The fuel is methanol......
Thanks,
Corza
Thanks,
Corza
