Here is a little basic information on the combination.
427" SBF, dart aluminum block
240cc High ports
CHI intake, Accufab 4500 throttle body
Solid roller cam, .768int/.753ex lift, 277int/290ex duration at .050 113° lobe separation
I have always had a hard time getting my car to idle correctly, with the old combo(similar sized cam with a tighter lobe sep and less duration) i would have to keep the car running for a little bit on cold start, but once it was warm it would idle ok.
Now, i have changed the camshaft and done a little bit of work to the heads and intake, and i cannot get the idle consistent. On cold start, it will idle at 1250-1400rpm, which i am OK with. It seems to idle the smoothest at 1300rpms. At the lower coolant temps the IAC is open 100%. Once the car gets warmed up after say 5-10 miles, the idle will hang at 1800 rpms, IAC at 0%. If i put the car in gear, and slowly release the clutch till it pulls the engine down, it will sometimes bring the idle down to 1300ish rpms. Other times it does nothing and the idle goes back to 1800, and sometimes it will idle down to 1300rpm for a few seconds, and then go down to 1000rpm, then down to 800rpm, then die. If i catch it with a quick blip of the throttle before it dies, it will rev to maybe 2200rpm, then come back to 1800rpm and stay there.
I have tried playing with some of the IAC settings in the idle tables, but nothing seems to help much, also, the idle screw is so sensitive on this thing that even 1/8 of a turn on it could mean the difference between idling at 1500, or not idling at all. I will be the first to admit that i am no expert as this and ive always been teaching myself as i go. Any guidance on where to look would be greatly appreciated.
240cc High ports
