1 - 20 of 206 Posts
Pretty typical spot for some rot ,the battery mounts just above. That mount is no longer needed with the Foxbody strut set up.
155410
Gone! Thinking about cutting out the front crossmember and replacing with tubing.
Discussion Starter · #12 ·
^ Thanks again.^ Shop time is like Disneyland for me!
The AJE K member had slotted mounting holes, didn't like,so I welded some 1/2" "weld washers" in place once the K member was square with the chassis.
155583
155584
You have the High Ram yet Brian? I have a forward facing one with a Holley ls throttle body. Won’t fit on my Brodix heads.
Discussion Starter · #19 ·
^ The car is very clean,has shitty paint/chrome,both staying,and no rust. It came from Cali.
The back story is I was planning to build a Falcon, bought a 65 ,also from Cali,on ebay,and when it showed up, it was too nice to cut up. Then came the Fairlane.
155816
155817
Just a 6 banger/3sp,but even the wife said "buy another one to cut up".
No,haven't bought yet.
1 - 20 of 206 Posts
