One of my guys was installing helicoils on a 4.8L LS Aluminum head because the old exhaust manifold bolt threads where pulled out, despite drilling straight in he touched a water jacket about 1/2 way down into one of the holes...
Now, the hole is going to have a helicoil in it, then a stud so I assume we can use an epoxy when installing the helicoil and be ok, what epoxy is recommended? I'd like something I can source locally if possible, not the stuff they use on ship engines that has to come in 55 gallon drums. In the olden days when porting heads and working on engines the guy I worked with swore by JB weld for these kinds of issues, is it still the go to?
Disclaimer, yes it is a patch. This is to fix a 188k mile motor in a delivery truck to keep a friend on the road, he's not paying normal labor rates and everything being done is a "just make it last as long as it can possibly last" repair.
