pulled the top end off a fairly new engine that has dyno time only and was built by a professional shop for somebody else. I was cleaning the carbon off the tops of the pistons and noticed i can move the pistons in the bore enough to see it visually and make a thunking sound. the engine has diamond pistons and the bores are nice with crosshatching still visible and No ridge. it may be fine but i dont ever recall being able to see so much movement. the erngine was built to be used with a blower and is a tall filled block also. bore is 4.360. any insight?
