wouls like to see pics of everyones engines- looking for some different ideas - thanks guys we did this on the nos section turned out great
Shout out to James in Aussy on another great build!
Look at the flat ass power!
390 SBC w/SRH RHS 2.72 DYNO TESTS
specs:
4.155 X3.6 SJ crank
6.0 oliver UL
Diamond coated Inboard pin boss 9cc dome .350" high
14.0:1comp cranks 215psi
.043 .043 3mm ring pack moroso 3vane pump 15-16"vac
T@D 1.6/1.5 rockers trend 3/8 .135wall pushrods
Pac 1324 springs @1.95 315seat
schoenfeld 1 7/8 step 2.0 with 3.5 collect 17" long
Edelbrock 2892 port matched and plenum clean up
Holley 850HP Ultra
Sweet! Looks like the track prep was OK! Well done.Finally raced this thing on a good track on weekend.....Running on alcohol with little 1 3/4 pipes with 3.0 collector,,,only making around 670HP,,,it run a best of 9.72@138.5
Getting ready to dyno this thing next week...
WOW, very nice.Getting ready to dyno this thing next week...
great powerPump Gas 565 842 hp 746 ft lbs
4.600 bore x 4.25 stroke
callies crank and rods
CP BULLET pistons 10 to 1 compression
Competition ported Dart 335 by Dr J.s Performance Ported Dart 4150 single plane
Isky street roller 258/262 @ .050 .680 lift
Isky ez roller lifters
Comp Rockers 1.8 7/16 rockers no stud girdle
Dr Custom 4150 carb
Yes 3000-3500 stallgreat power
just wondering why the test was started at 3000rpm? obviously a street engine, will it have a convertor that small?
honest question
Holy Intake Batman..........good lawd!Intake / pushrod mockup. Going to have to do alot of grinding.
[/IMG]![]()
Nice launch!Finally raced this thing on a good track on weekend.....Running on alcohol with little 1 3/4 pipes with 3.0 collector,,,only making around 670HP,,,it run a best of 9.72@138.5
Dayuuuum .... look at that torque curve. Sweet!Pump Gas 565 842 hp 746 ft lbs
Dr Custom 4150 carb
Very nice. What are the cubes?Getting ready to dyno this thing next week...
