Styno ... Nice & Clean, looks good. I've been trying to following your build on here. What are your 1/8 mile times? Also have you ran it with slicks yet?The mule!
thanks for the info..thats where i want to stick my pt88..i been looking into kits..i'm just going to take a fox body kit and weld diff header flanges on it seeing i'm going with a lsx engine.It's half and half. The hotside was originally a street kit built by HP Performance (www.turbochargedpower.com). It was then modified from a T4 flange to a T6 flange so I could run a large frame turbo, and the entire cold side was custom fab'd by a local shop (Fatal Performance). The frame rail also had to be notched to clear the large frame turbo, so it wasn't a bolt in affair.
Here's an older pic that's a little bit brighter.
