What are the pros and cons EFI vs Carbs? On a 632 with spray
I'll try to assist. I'm a tuner of the Holley Fuel Injection Systems. Mainly Drag race Only cars. I get into a street ride occasionally, but not much. Most of my cars are Stock and Super Stock cars. If all your after is drivability and cold start issues, I think you need a true carb specialist to help set you up in the right carb and help you figure out why you hate what you have.. There are shit loads of people on this forum that have great carbs that do not act like yours. Seek them out. Start a new thread lookin for what you're looking for in a Carb Specialist and builder. It might not "just" be your carburetor. Timing or spark issues will make your problem worse. But maybe you already been through all of that...I didn't want to start a new thread on what I'm sure is an beat to death topic, so I jumped onto this old one from 2015, just because the title came up when I searched.
BBC, runs great with my 850 double pumper. I have only two issues, and they may both be due to my not knowing how to adjust a carb.
1. Erratic idle. I set the idle, it works great, I drive somewhere, and it's too low. I adjust it, and drive it more, it's too high. This is constant, but worse if I start on a cold morning and it gets warmer.
2. The Holley 850 I have was professionally built, and the guy that built it milled off all of the provisions for a choke. The damn thing won't idle until the block hits 160 degrees no matter the outside air temp.
I live in New England, and to be blunt, I am fucking sick of this. I have always been under the impression that if I had EFI, all my problems would be solved. But all the people I know that run built big blocks run carbs. Mostly because all my friends are cheap pricks. I'm not trying to be the fastest guy at the track, I think that ship has sailed, I just want to be able to move my car without waiting 15 minutes for it to warm up, and without the damn thing backfiring and popping 12 power valves per summer, and I'm willing to spend $1500 on EFI to achieve that if it will help
