I worked at Dart for 3 years. I've seen a 2000 hp turbo small block rip the mains out. Dart has since added more material around the bottom of the cylinders and the newer aluminum blocks could probably hold it.
I would still run iron. More specifically, spend the extra money and special order a Dart block in Compacted Graphite Iron. It will cost you an extra $1000 or so and take longer to get. It's a better choice.
First, turbo cars usually have to weigh more in a class so weight savings isn't as vital as in a nitrous or n/a car. Keep in mind aluminum blocks were originally intended to save weight in naturally aspirated circle track/dirt track cars, not forced induction drag cars.
Second, even though a cast aluminum block may hold together it WILL flex like crazy compared to iron. You'll lose power in ring seal alone.
Third, a CGI block is something like 70% stronger than the standard iron. It won't distort, it will seal better, it will hold internal components tight and you'll break the crank first. Unless you totally grenade the engine it will be the last block you ever buy.
If you're dead set on aluminum and have the budget then billet would be a better choice than cast.
