5 page article in new Hot Rod magazine.
355 SBC.
Dart Block
RHS 180cc Aluminum heads
9.2:1 compression
236/248 @ 0.050" 0.520"/0.540" 113 LSA cam
Edelbrock Pro Flow injection w/44 lb/hr injectors
Edelbrock single plane (carb style) intake
Aeromotive boost referenced pump. max 60psi.
Naturally aspirated, it made 422hp @ 6100 rpm on pump gas. Needed 42 degrees of timing.
5psi boost. SAME timing and 114 octane, made 655 hp at 6100 rpm.
8psi boost. SAME timing and 114 octane, made 836 hp at 6100 rpm. 36 degrees cost 50hp.
Compressed Air Supercharging has zero parasitic drag, and the air goes from 3300 psi to 8 psi... so theoretically, the air hits the intake at -200ÂşF and has incredible charge density. One explanation for the high timing was the extreme cold not vaporizing the fuel very well, and requiring more time to burn.
The magazine has a website listed, but as of right now, all that's there is the company logo.
http://casupercharging.com/
Not my info.... Just passing it along... so don't kill the messenger. lol
355 SBC.
Dart Block
9.2:1 compression
