10.5-11.5 air fuel ratio at wot throttle.
9.5K views 19 replies 12 participants last post by  yeti
I just got my lm2 hooked up and I took my car for a spin. It has been pig rich and I didn't just want to start stabbing in the dark with jets. As of right now, it has a 2.5 power valve and a 74 / 85 jet spread.
One of the lm2 sensors is not reading correctly but the other is working fine. At idle it is around 14.5-16.5afr. Under wot, it is closer to 10.5-11.5afr. Cruise is around 9.5-10.5.
Where do I start, because something is wayyy off?
Thanks guys.
#4 ·
Sorry, it's a 750 holly double pump with the choke horn removed.
I have heard of people blocking off the power valve, would this be wise in my situation? It seems like I have the jet spread for it.
#6 ·
It is far from a daily driver, but I would say it is 50/50 track car street car now. It spends just as much time on the track as the street and when I do drive it on the street, it's for short trips to meets and stuff.
#9 ·
The plugs are fouled up and get that way rather quickly. Last year at the track the car got quicker when jetting down the secondaries. It picked up 3 tenths jetting down a few sizes, but was still stinkin rich. That's another reason I believe my lm2's afr reading. Reason why it still has the jets in it that it does is because I ran out of track time.
#12 ·
This is a great document to keep handy. It has the factory calibrations for most models. On a new combo, I always try to return any used or rebuilt carb to factory specs and then tune from there:
http://www.holley.com/data/TechService/Technical/Carb Numerical Listing.pdf
Assuming this is a 4779 Holley 750 mechanical secondary, it says the factory jetting is 70 front, 80 rear or 71 front, 80 rear depending on the year/model.
#13 ·
Alright, I swapped the main jets to 70 and the secondary's to 79, it seems to be alot crisper when you rev the engine. (It's raining so I can't drive it to find out)
However, I do believe the 2.5 powervalve is now opening at idle due to the rough idle, smell, and visible smoke in thr exhaust. Plus, the lm2 is reading anywhere between 8-10afr at idle. I'm not sure how to get the propper vaccum reading to find the propper powervalve for it with it idling this way.
Should I pull the 2.5powervalve and put a powervalve block off plate in just to get the propper vaccum reading to know which power valve I need? I think it would work just to get the propper reading, but you guys have alot more experience then I do for sure.
#15 ·
No, do not block off the powervalve if you do ANY street driving... try replacing it with a 6.5... get you primary jets set via light to medium acceleration(20-35% throttle) then set your secondaries via WOT...
#16 ·
Chances are you will have a hard time getting your WOT AFR correct without being rich on cruise even with a higher power valve (which I agree with others you should try) unless you open up the PVCR's and and drop the primary main jets accordingly.
#18 ·
Get your self a vacuum gage and a holley tunning book ,don't always trust what you read on the TARD NET.Then you will be able to choose the right power valve,and read your plugs to find the right jets.
JT
