You guys need to tune-up the transition slot mixture by using a restrictor in the gasket face of the body in the passage to the T-slot.
The T-slot in Dominators is too long. T-Slot above the throttle blade is air bleed until the blade is opened up the slot, then it becomes fuel feed. When the blade is low on the slot, at idle and low engine speed (staging, burn-out, return road, etc.) the long slot is too big an air bleed and as the throttle is opened it becomes too big a fuel feed. At low throttle, the too big bleed condition requires a small bleed on top so it will run at all, then as the throttle is opened and the slot ceases being a bleed, it gets too rich because the slot is such a big fuel feed.
The solution is a shorter T-slot (which is available in a custom carb from Bo Laws Performance - they machine the carb body and install an insert with a short slot) or simply put a jet in the passage feeding the slot.
Most single carb Dominators will run well with a .040” idle jet and somewhere close to .070” idle air bleed with a .052” T-slot jet.
Dual carb Dominators need smaller idle jets because there is twice as many of them. Dual carb IJ, .030” or less, with IAB near or smaller than .062”.
The Dominators are not all the same because of random T-slot locations in different production runs of carbs. Because no two carbs are the same but mostly because no two engines are the same, the air bleed and T-slot jet can vary. Again, most single carb Dominators will run well with a .040” idle jet and somewhere close to .070” idle air bleed with a .052” T-slot jet.
Usually, it is best to start with a T-slot jet of .052” and play the Idle Air Bleed between .060” and .090”. If it acts too lean at small throttle, raise the T-slot to .055” and play the idle air bleed up and down again. Rinse - Repeat
The deal is to start out with the idle and low speed-transition circuit so lean it won’t run well and then sneak up on it adding a little fuel at a time until it runs smooth. Just add enough fuel to make it run without being stubborn when it is warmed up. This way you find the minimum amount of fuel, the “lean limit” for low-power running, which will keep the engine clean when it is only making 20 to 50 HP. A race engine does not need a power AFR when it is only running at 10% of its total power.
This is the opposite of the plug-fouling condition you have now. A correct idle circuit tune-up will be cold-blooded. If your carb is rich enough to run the engine without warming up for a few minutes, it is too rich and that is the reason your plugs are fouling.
(Of course, be sure your fuel solenoids are not leaking.)
