Always posts asking about what's the best trans fluid. Is there any bad transmission fluids to stay away from? Are there any documented failures from someone using a particular trans fluid?
Blasphemer!The worst fluid is overheated. If you can keep it cool anything will work. Currently mine runs JR1 synthetic. Clutches and band have well over 400 passes. They look like they just came out of the box.
Doug
Water will work, just not very long.Just use water.... ?‍♂ WTF
It might have something to do with seal compatibility. Apparently Dexron VI is not recommended by Allison in certain transmissions (depends on the S/N) --> "...DEXRON-VI caused Viton (FKM, fluoroelastomer) seals to harden and crack". But, this would only apply to Allison transmissions.Guys are saying to use the Alison Tran Synd synthetic fluid. The Alison behind a relative's 8.1 says to use Dexron VI. Are the transmissions that different, that the gasser uses Dexron VI, and the diesel uses the Tran Synd? Also I've read that Alto clutches and Raybestos steels, do not like synthetic fluid. Any truth to that? Finally are there two versions of Dexron VI, mineral and synthetic?
I have been using it for years. Zero issues and when I have taken the trans apart it's always clean. I like to run 303.in all of mine.What are the pros opinions on the tractor hydraulic fluid?
Seal composition.Why in the world would dex-6 "attack" seals in an allison but be fine in over a million other transmissions?
Not calling anyone a liar...just hoping someone can explain it to me
Which one is that? Take care. Tom WorthingtonLots of hate for Type F. Note that not all Type F fluid is created equal. The one I use has a good bit of anti-foaming, a high flashpoint, and doesn't "coke" at all.
The worst trans fluid is no trans fluid.
