What's the difference between dominators and "tunnel ram dominators"
13K views 24 replies 14 participants last post by  Steve.k
I have a big chief 598 with 2 foggers that has a sheet metal tunnel ram that I bought with a single dominator top on it. I am almost done freshening and am putting 2 dominators on it. My question is what is the difference between an out of the box set of 1050's or 1150's and a "matched set of tunnel ram carburetors". I have a buddy that will give me a pretty good deal on a new set of 1050's, but it's not such a good deal that I can't call pro systems or some other company and have a set built for a little more. What is the "setup" that is done?
#3 ·
When I went from one carb to two, there was a little tuning involved, but not much. Biggest thing was to make the carbs both the same and when you make a change, you do the same change to both. Have since gone to injection (mfi for alky), but still have my carbs.
#5 ·
The common difference is the linkage ratio, as with the carbs crossways most tend to use 1:1 linkage instead of progressive. - That said though, I have the progressive linkage in my pair to lessen how touchy the throttle is with my pedal ratio/linkage.
Beyond that a good custom set will likely have the idle fuel and air bleed circuits metered differently, as you have 8 idle circuits instead of just 4 yet the motor is still going to want the same amount of fuel at idle as it did with just 4 circuits.
#8 ·
#13 ·
I use 2-circuit carbs on single set up and 3- circuit carbs on dual set up. I ran a pair of 1150 holeys on my 540 with a off the shelf holley intake and was very easy to tune coming off the trans-brake and 8100 in the traps.Also got a nice idle around 900 rpm. This was in 1992 and don't know how the modern carbs are for quality thou.The 3rd circuit is supposedly for transbrake rpm and a clean leave,worked for me.Tom..
#19 ·
I put a 3-circuit on my 548 street Monte (by mistake) 1050 cfm and I chased that damn thing for two summers.It still doesn't perform as good as the 2-1150's on my tunnel ram 8100rpm( max ) 540 race engine. And maybe that's the clue,maybe the 3-circuit is calibrated better used in pairs on the tunnel ram. I even had a holley guru come over and work on 1050 and he couldn't get any closer than me. And after messing with it for several years and being tired of fighting with it ( I have oxygen sensors on it) everything was pretty good except high rpm went lean. Put 100 jets in it and still went lean. I was on the Team Chevelle sight and posted about it and a gentleman by the name of Mark from Fla. told me to drop the high speed air bleeds down about 18 sizes. Seemed risky but he works on these carbs ,his business,so I tried it and low and behold it was super rich,100 jets still in it,.Worked the jets down to a reasonable size and the AFR came right in. Great! so off to the track we go and after 1 pass the trans blew again,4 th. time for that, 4L80E, now my trans guy won't even work on. So it's been in the barn for 4-years,i'm pissed at it. And so it goes.Anyway The intermediate on the 3-circuit is suppose to work with a trans brake and or tunnel ram.Mark from Fla. said the same thing that the 2-circuit would work better on the single carb,said he could convert it to a 2-circuit at his shop,or he would sell me the parts and I could do it. It runs pretty good and I'm still pissed at it and don't have a trans. I'll worry about it later. Tom.. PS. Sorry for the book length version.
#17 ·
Don't really need 3 circuit dominators on single carbs with transbrake use unless maybe throttle stops. Mostly "more is better" mentality promoted by Holley, (like 5 emulsions is "better" than the original 2 that worked fine.) When annular boosters came along on 4500 carbs, it was for very limited applications for tunnel rams and individual runners, which did not last long. The annular boosters were carried over as they helped and the 3 circuits just came with them. Dominators as big as 1250 singles work just as well or better as 2 circuit than the intermediate 3 circuit and are simpler to tune. (Just my experience.)
#20 ·
My 468" & 557" both used the 3 circuit 8896 and they ran excellent.
The 468" used to get tons of attention it ran so well, 9.30 at 3000 lbs,
small tire car with crap 60' times was getting it back then.
#22 ·
I used a three circuit dominator at first when it was a single carb. Had some serious tuning issues. When I got it tuned so it would run without fouling plugs down low and loading up, I couldn't get enough fuel to it on the top end....converted to two circuit, problem solved. When I went to duals, two 1295 king demons, never even tried three circuit. Both converted to two circuit, easy to tune, responsive, and great drivability part throttle. You don't need three circuits on anything we do.....and most three circuit carbs are way out anyway....Dave Braswell uses 4 or 5, but he's also changed where the discharge tubes are located in the throttle bore, which affects when the circuits become active, along with other changes......BUT......If a carb is properly matched and properly tuned to the engine its on, there will be little if any difference in performance going from one carb to another, keeping the same criteria...
You don't need a 3 circuit....two works perfectly and is easier to tune....
