Trans cooler recommendation
1 reading
8.1K views 11 replies 10 participants last post by  sgsst109e
Th400 trans , street strip car with 5500 stall convertor. What cooler would be the best choice ?
#6 ·
I have a 5000lb Bronco with a converter that goes 5000ish. I run 2 of the 70266 B&M super coolers which are just stacked plate Long coolers. 6an lines and coolers are mounted in front of rad.
Driving on the road and beating on it the trans will get to 160-170 is all i can get it to on the road.Hydraulic oil for fluid.
Using trans brake a lot is the only way i can get temp up over the 160-170 normal temps.
#9 ·
This is the large tru-cool cooler and the lines are also routed thru the radiator cooler which I recommend. My car is a turbo so it has to endure sitting on the transbrake and this setup has been fine for 13 years.
