Hello I´m working a lot on my 68 Mustang and I talked to Wilwood and they told me that I need to change my setup and put the front brakes on the rear port of my master cylinder and the rear brakes to the front port of my master cylinder.
But I know when I brake aggressive and hard that my rear tires can lock up also at higher speeds but my front don't. And that is with the usual setup front port to front brake and rear port to rear brake. All around Draglite Wildwood 4 pistons.
I use this master cylinder Wilwood 260-15521-BK
Does someone has a good idea on that and is it really necessary to do this, I´m scared that there will be much more braking power then and my rear will lock up more than now and maybe faster.
Thanks for the help.
And yes the car is very light with full aluminum engine etc.
