So I'm having an issue with too much slip (14%) with a converter that was spec'd for much more power than I'm putting down, and as I increase power the slip increases. I suspect the converter is losing fluid pressure, I am waiting on a pressure sensor so that I can log the pressure in the cooler circuit and make sure. Line pressure is 180 in all the gears, RMVB.
I suspect this because the feed is restricted to .125, and at the advice of an experienced trans guy I left the bushing out of the stator tube, even though my billet input shaft has lube holes. I think the escape path of converter fluid flows too freely for the size restrictor I put in it. 6an lines and b&m supercooler.
When guys are measuring the pressure in their cooling circuit I have read where some read before the cooler, and some measure after the cooler. If you measure before the cooler, it seem's like you're getting a more accurate idea of what's happening in the converter, as if you read on the cooler outlet, a restrictive cooler can make your #'s low, as the fluid would be able to exhaust easier between the cooler and trans.
My idea is to put a 6an union with a gauge port inline between the outlet of the transmission and the inlet of the cooler, and use a set screw in the gauge port to apply a restriction in the line until I achieve desired pressure reading on the outlet of the transmission, measured before the restriction. It seems like this would be a good way to know what is going on in the converter and dial the pressure in, without having to remove the transmission possibly multiple times to mess with the pump.
Is this a good idea, or stupid? Has anyone seen this done before? Maybe I've been living under a rock, and guys have been already doing this. If so, does anyone sell the parts to accomplish what I'm looking for, before I re purpose a gauge port adapter?
