I think the trick to making them work is starting with the 69 to 74 blocks. Zero balanced, studs, girdle, filled, and keeping the rpms low. Out of all the power adders the turbo is the easiest on the rotation assembly.
Next rebuild I will be curious to see my bearing and cap registers. Shooting for 8s this spring, already been 9.47 @ 3200lbs supercharged at 11lbs on a 393.
