So I want a 2500hp Big Block Chev with a Roots, Ideas?
7.6K views 9 replies 6 participants last post by  Mitch H
I want to build a bbc roots blown combo that can reasonbly make 2500fwhp . I would love to here some advice from guys doing it , i know a hemi will do 3000-3500 so surely 2500 is not too much of a stretch?
Parts i have are Dart block tall deck, AFR 385cc heads, Bullet pistons 4.560 with 20cc dome , 4 , 4.25 & 4.5 inch cranks . Can build a combo from 522 cube to 588. Littlefeild 1471 LB20, tunnel ram style intake,
Carbon fiber hat, 990 pump. All new parts.
I think a 522 with a 6.7 rod would be best combo but open to any suggestions , I do not have rods or camshaft yet. Is this blower enough? Thanks .
#2 ·
The blower can be,.....depends on its condiction. Forget focusing on a particulate rod length. Focus on the ring package placement and where the pin needs to go and that will dictate your rod length.
#7 ·
Did you ever move forward with this build?
That blower might make 2500 in the right air, but you will be pushing it. IMO, you will also be pushing a 4.560" bore. You will need some RPM to make 2500hp.
Roots blown Hemi's can make 3000hp because their valvetrain is a LOT stouter than a BBC, hence bigger RPM.
My BBC combo consists of a solid aluminum Arias/Century block, 14 degree Big Chief's, a bullet proof rotating combo, and a very good, worked over SSI billet 14-71. I don't know if I have the nerve to run it at 2500 very much. I should have just started out with a hemi.
#9 ·
No haven't done anything, that was just about when covid hit. ready to get going again though.Just trying to be different, didnt want to be another turbo car.
#8 ·
Got one right here, ready to go that is 2500 capable all day. but it has spark plugs in the valve covers. LOL
A good start would be, solid block, billet heads, 4.375" bore, 4.000" stroke, 10.5 compression, GRP aluminum rods, Bryant crank, stainless ***** top ring, gapless second. R296/500 Crane cam, 14-71 high helix. MSD 44 mag.
Or see above.
