Snow blower to power broom conversion?
1 reading
11K views 31 replies 14 participants last post by  BigLar368
Anyone done this?
The closest thing I've found is this:
He has several more videos, but a 3 point hitch is not how I would do it. I have a extra lawntractor and snow blower. Finding an inexpensive broom could be difficult.
#2 ·
Explain how you're going to do it. I assume it would have to be a single stage instead of a dual stage, and would you block up the exit/discharge shoot and just have the broom brush forward?
I am sure it can be done, but sounds like a lot of work for a less than perfect machine when you're done. What kind of stuff are you brooming/pushing around?
#13 ·
I work for a city and operate a street sweeper, I have about 21 used centre brooms that always get thrown away every so often.
Go to your city roads dept, they might have something for you.
Dave...
Anyone done this?
https://m.youtube.com/watch?v=23SfSNA9pcY
#17 · (Edited)
Anyone done this?
If you look real good you can see 1Gary welded that thing together!
#19 · (Edited)
Over $2000, and my tractor isn't a JD. Maybe you're suggesting I copy it, don't know. It does look like the second home made broom video I posted. Thanks I'll have to get the manual for that.
I'm still thinking converting the old snow blower will be easier than from scratch. Maybe not, I'll post up the result some day when it is done.
http://www.imdl.gatech.edu/jfrankel/docs/Backhoe_Manuals/tm1763.pdf
#21 ·
I was mainly giving it as an example for the folks who didn't understand what you were thinking.
The important thing with brooms is the contact pattern. You want to have the broom bristles "flick" the dirt, not drag it. That generally means a contact pattern 1-2" wide. Cater wheels with adjustment washers work very well. If you're going to do power angle, the pivot needs to be vertical, and the cylinder parallel to the ground
#23 ·
He's gonna be disappointed in that one he built when he gets it running. Usually the individual brushes are "wavy" not flat like the ones he installed on the homemade piece. Its gonna leave un swept areas in between each brush. I'd look for a good used commercial grade sweeper. and quit wasting time and money trying to build something like that one in the video. We have several we use at work they all seem to work well but require regular maintenance. and one guy not knowing how to use one can fuck one up in a hurry.
