Second stage fogger retard activation
161 views 3 replies 2 participants last post by  BLUEOVALRACER
I wired the first stage like MSD shows the relay with the diode and the pink wire going to the positive side of the coil. I ran the WOT switch hot through a transbrake relay to two stage switches and back to the positive side of the relay coil. The first stage turns on with the release of the transbrake, the second turns on .5 seconds after with the activation of the brown/white ground(-), purple wire on the (+) side, but the retard activates with the release of the transbrake button, is there a way to make the second stage activation control the retard?
#3 ·
Thank you, moved.
  • Like
Reactions: BLUEOVALRACER
