Racing Oils & Lubricants
1 reading
18K views 54 replies 28 participants last post by  Bad Mannerz
As a disclaimer, I am a sales rep for Schaeffer's Oil but also a Certified Lubrication Specialist (CLS) and a member of the Society of Tribology & Lubrication Engineers (STLE). Now that I've got that out of the way, I'm also a drag racing fan and was a machinist for 25 years before coming to work for Schaeffer's. I am in the process of testing every racing oil currently on the market with virgin oil analysis as so much has changed since I last did this back in 2014.
I'm also going to have an article published in a major engine builder publication regarding all the recent changes in the motorsports industry. I would appreciate any feedback regarding the following subjects:
1. Will Valvoline's recent sale of it's lubricant business to Saudi-Arabian state-owned Aramco affect it's VR-1 line?
2. Reladyne's decision to discontinue the Drydene Racing Formula (DRF) product line after they bought out PPC?
3. DA-Lubricants decision to move production of Penn Grade (Brad Penn) out of Pennsylvania to the Midwest?
4. Driven's decision to move to the old Brad Penn plant to produce their new GP line? Brilliant move in my opinion!
5. Champion Brands being sold recently to billion dollar company PLZ, which is owned by a group of investors?
6. Royal Purple being bought out by Calumet and changing their formulation?
7. Are you starting to see a pattern here? Why are these lubricant companies are being sold to venture capitalist firms?
8. Has pricing ,consolidation, and availability since Covid, affected your purchasing or brand preferences?
9. What are racers looking for in a racing oil and are we as suppliers missing the boat on anything?
10. What is everyone running for transmission fluid? ATF, Ford Type F, Allison Fluid, or Universal Tractor Fluid?
In closing, feel free to add anything I may have missed, and I'm open to criticism of our lubricants as well, as we are always looking to improve our product offerings and we can not do that without feedback from the racers!
Thanks,
Alan
#2 · (Edited)
Driven GP1 semisynthetic oil formulated @ American Refinery in Bradford Pennsylvania is Brad Penn oil with different additive package and indeed a good move.
Allison Castrol Transynd 295 is about the best trans fluid going for performance or towing except for the newer Transynd 668.
Cenpeco and Shaeffers are not that well accepted to this point.
#3 ·
Allison Castrol Transynd 295 is about the best trans fluid going for performance or towing except for the newer Transynd.
#4 ·
Thanks for your input Mark! And yes you are 100% correct! I'm friends with Lake Speed, Jr and filled me on the whole deal with Brad Penn. Stupid move on DA-Lubricant's part as the old Brad Penn was an excellent oil but I can understand the move from a business standpoint as most lubricant manufacturer's view racing oil as a liability which is why RelaDyne (PPC) dropped the DRF line as they only wanted the Drydene Heavy Duty Diesel Oil (HDEO) which commands the largest market share and margins for engine oils.
As far as the Castrol Transynd 295, that would be my second choice however the results we are seeing with the Caterpillar TO-4 10 weight are even better.
As far as Schaeffer's presence in the drag racing community, I couldn't agree more but we are working on that with some great testimonies on YouTube regarding our products. I'm came from the dirt side of racing having been involved with numerous teams in the World of Outlaws Late Model Series and the Lucas Oil Late Model Series and although I did a little drag racing when I was younger, I kind have gotten away from it until recently when we got involved with some Pro Mod teams.
Thank you for your input! This is exactly the feedback I am looking for!
#7 ·
Brian I have been in involved in the lubrication field for 25 years and I have never seen the changes and consolidations that we are currently seeing in the industry. I don't get involved in politics, unless the customer brings it up and then it's fair game, but if we don't change course, we better start learning to speak Chinese! Lol
#15 ·
I had a talk with a young tech at a local dealership recently that had worked with Southwest Research Institute as a tech running oil tests for customers getting there wanted / required specific oil ratings, he said that during testing there was lots of times the oil failed its required testing in the specfic way/ order it was to be tested so management had them change the order of the testing til they past the certification test [Big paying money customers from China]. After a year he caught onto what they were doing and left.
#10 ·
My oil thoughts
You get what you pay for. If your motor runs fine on Wal mart house brand it means you are not stressing the oil very much not that it is a quality oil.
Use an oil that is designed for what you are doing. Karting oil in a kart, diesel oil in a diesel, etc…
Pick the oil weight based on oil temperature .
I
Base your bearing clearance on shaft diameter .
Once you choose an oil stick with it. I have seen issues and I believe them to be from oils not blending with other brands.
Dyno testing oil is of little value, Oil temp ,contaminants , testing different weights etc…. Hard to get accurate data.
Wear at the end of a life cycle of an engine is the best indicator.
#18 ·
My oil thoughts
I
I agree with the oil weight based on oil temperature. I can't believe how guys with high HP cars don't automatically have an oil temp gauge.
I will say that bearing clearance is dependent on journal diameter but should be increased from "standard" if the car has a power adder. The worst rod bearings I've ever pulled out of my engine were the ones I set up with .002"-.0025" and coated. All other times I've used uncoated bearings with .003"-.0035" (SBF) that has 2.249"/2.123" (main/rod) journal diameters.
#14 ·
I'm also not opposed to paying a little more for a quality oil, especially when you have a fair investment in your engine.
I really don't understand people that invest $$$$' s into a engine, then make the choice of oil they use based on price.
I heard many times " I've been using this for years with zero issues ", but without comparative data from oil analysis who really knows.
I suppose that's also the case with the oil I choose to use even though I consider it better than cheap oil.
#16 ·
Have run both Shaeffer's and VR1 for the last 2 years. Have a few black particles in the oil filters and in the bottom of the oil pans. Assuming it's a little moly settling out of the Shaeffers, it's not really a solid and can't feel anything rubbing it between 2 fingers. Not a complaint, just an observation. Have had zero issues with either oil, methanol fuel 180-195 degees water temp.
Have tried the Transynd oil and was suprised to see 15 to 20 degrees warmer trans temps in round-robin situations. Best I've found is any tractor type hydraulic oil, best being Kendall 052. $80/5 gl. Reason for more trans temp on the Transynd I feel maybe less viscosity and we slip the convertor a bit more than what is considered normal.
#17 ·
Samples I had run in 2019 - Royal Purple XPR, Redline Racing and Driven XP3. Lots of good information in that whole post.
Jason G.
#21 ·
After my last post I went out and found the used "tight" coated bearings (I keep old bearings). In the first picture you can see the highly loaded upper rod and lower main bearings look bad, it appears the babbitt coating is worn thru. In the second picture you can see the bearings I ran with looser clearances.
#22 · (Edited)
So, what does this accomplish and what's the outcome of the change on the final product?
I strictly use Brad Penn "The Green Oil" in a 10-30/40 weight in our methanol injected BBC. I ask my machinist about using Schaeffer's since my friend/fuel dealer started selling Schaeffer's. My machinist said not and to stay with BRAD PENN.
#27 ·
the current brad penn is not anywhere close to the same as the old brad penn
the GP1 stuff is very very good oil, we use it a lot
I also am a big believer in the BadAss/HPL oils
we have used and sold GP1 and BadAss exclusively for 3-4 years
Through the prostock stuff, i got to know David at the place they make the oil
#23 · (Edited)
Driven representative at PRI this year confirmed the GP1 is the old Brad Penn oil. They did make an additive package change to what he said is a more current one they are using in their other product that is superior. to the 20 year old package Brad Penn was using. It is entirely formulated and packaged at Bradford Pennsylvania's American Refinery.
Only bad side effect is the price is higher and less places to get it wholesale. Jegs does sell it retail by the bottle or case, but no discount by case. And then there is the minimum purchase needed to get free shipping. Summit has a lower minimum. The warehouse I used to get Brad Penn does not handle Driven.
This post has been deleted
#40 ·
The first set of bearings with coating look to have excessive abrasive wear from fine grind particles
They look prematurely worn to copper
What oil filter was used on this engine?
The same System 1 oil filter I've used for over 10 years. I do seem to remember the original filter came with a 45(?) micron element and later I changed it to a 30micron filter. Recently I bought a new System 1 cartridge and am now using a 35 micron filter element.
#53 ·
I ran Rotella 15w 40 T4 in my 500" sled pulling motors using a System 1. Never tightened the chain before the oil got to 175*, 210* at the end of the hook (usually) Always shot for 8200 at center track before the pan dropped. Every tear down the bearing looked new. Every now and then you might see a spot where a piece of trash came through but that was isolated. For the turbo buid I called JGR, gave them all my clearances and how it would be used, and they specked the oil. Gp-1 Blend 15w 40
