Working with a set of RR23 degree Brodix heads. .180 offset lifter .450 offset T&D's. 7/16 double tapered to 3/8 Trend pushrods. Have a couple that are rubbing on mock up. .550 offset is the max I can go on my rocker setup without going to a wide body design. If that will get me there ill swap them.
SO................whats the closest clearance you can run the pushrod to the head???
