Hey guy's,
just my 2 cents worth from across the pond...here in Oz we run a 69 camaro in a drag radial class, thats still what i would call a street car, it's a very basic 496 truck block deal with off the shelf edelbrock performer heads and a 650in comp roller, 2000cfm 4500 flange t/body with a morris hat...that's all fed by two plain bearing 4202 garret turbos mounted in the trunk which in turn feeds the engine through a 3" charge pipe that runs back through the car...the hot side consists of hooker 2 1/8 headers into twin 3" back to the turbos which have Tial v-band 1.00 a/r housings.
We run a powerglide with a Chance bolt together converter (i guess the most exotic part of the car), the rear end is just a leaf sprung 9" with 3.5 gears and caltracs, on 275 radials, it's all steel, all glass and weighs in about 3800lbs wet...it's efi thats been set up and tuned by myself with a little dyno time but most tuning being done at the track...i have been playing with the rearmount deal in various forms now for about 4 years and has evolved from a single 88 to the set up we have now...the best thing we have found from the data collected and laps made is that unless you have tried a certain combo and know what's happening in the pipes, the seat of your pants, the time slips and most importantly your data logger, don't waste your time listening to all the "specialist's" out there telling you how crap your combo is and how "that rearmount shit will never work!"
As we live about 100 miles from the track and I work in a family business, my time isn't as free as i would like, our race season has ended and we are left with some mid week off street racing where the track is less than perfect we have managed to make a few passes to test, with some ordinary 60' times in the 1.6's the car managed an 8.8 @ 163mph... our data tells us it was making 18lbs boost and had 18/19 lbs back presure at the housings, afr's of 11.1's and egt's in the headers of 1700 deg f, on pump gas with no intercooler...we have a water meth spray to still test but we've just run out of time.
My point is guy's, if front mounts work for you sweet but don't write off the dude that wants to try a different deal...our gear is nothing flash and i would think we're getting towards the end of our truck blocks reliability... so with some real good parts i think the rewards could be endless, Cheers and thank's for listening, George.
