You hear of guys running extreme (like -10) pinion angles to make em "hook harder".
What is your opinion???
Just a survey........
It does on certain cars.Pinion angle does nothing for traction.
I have found that moderate amounts helped my ladder bar car. It was years ago when I played with it, but it had a very definite effect even when keeping other factors the same. The theory above is the best guess I had for the response.I was at a Dave Morgan seminar years ago and the discussion was concerning excessive pinion angle and it's effect on traction. There were people in the audience who were dead certain that it (lots of angle)had helped their car hook, and Morgan agreed with them. I then asked a question which in a nutshell was "Why?". Everyone agreed that it worked, but how? 4 links can be explained, as can ladder bars, but I had never seen a force-vector diagram of pinion angle. SOMETHING had to be pushing down on the tires.
That something, as explained to us, was bind. Lots of torque being transferred thru a u-joint with excessive angularity tends to stiffen the joint up, so as the mass of the car rotates, the joint tries to straighten out, and a force is fed thru the driveshaft directly to the rear end, bypassing the suspension.
I'm still not sure I understand it 100%, because it seems to be something that can't be expressed as an equation, and that puts it in the "Black Magic" area, for me at least.
Mark
