Oil pressure regulator for Ball bearing turbo?
3.4K views 11 replies 8 participants last post by  vw_chuck
I'm going to switch from journal bearing turbos to ball bearing.
Is a turbo Oil Pressure Regulator good, bad or even necessary?
I've read that I need a restrictor about .045", but is that together with the OPR? Or ?
My engine makes about 55psi at idle and 110psi at 8k
What's the right way to do this
#5 ·
WIth a turbo you have to limit the MAX oil pressure or it will blow oil out the seals. You can do that however you want. I usually use a mig welder tip with a .035" orifice on a ball bearing. Ball bearing and journal bearing have different specs for max oil pressure so you should ask the manufacturer.
#7 ·
What I have learned is that you do not want to over oil a ball bearing turbo. Restrictors were the way in the past, but now the regulated oil pressure is the way to go.
Journal bearing turbo's are the opposite, feed them as much as you can.
I picked up a turbo smart oil pressure regulator, and am not going to run any additional restriction.
#8 ·
Isn't this dependent on oil pressure though? Wouldn't the volume be different depending whether you have 70 or 110 at WOT?
Your comment is my question, and perhaps the OP's, should I run a restrictor AND/OR regualtor?
This topic is a mirror of questions I have because I'm running a Ball Bearing turbo for the 1st time. I've never ran any type of restrictor with S400 frame journal turbos. I've always used a -10 drain and never had any type of issue. But obviously, a Ball Bearing setup is differnet. I'm willing to do what ever is needed, but the question is still valid. I did add a .090 restrictor, but I'm yet to make a run (and won't for another 3 weeks).
I've reached out to the turbo supplier, but am yet to hear back.
