http://www.northerntool.com/shop/tools/product_200594735_200594735
any feedback on this unit? normal harry homeowner stuff
I bough one a grade better about a year ago, the Pump is a little beefier. So far no issues with 100 hours of run time. That being said I learned a lesson with a Craftsman. I mounted a whole house sediment filter on this one. Rebuilt the pump on the Craftsman several times while hardly ever using it.![]()
Not true if it has a Honda motor,the motor will outlast the pump...Nothing much better than a 5 hp Honda, cat pump and 4000 psi 4+ gpm... I've used this combination daily for years with normal maintenance only...Pressure washers are hard on engines. More hp is better, and 6hp or 212cc would be a minimum. The Northern is only 163cc or about 4hp. I agree that a horizontal engine is better than a vertical for a pressure washer.
I like this unit because replacement engines cost very little.
http://www.harborfreight.com/3100-psi-28-gpm-65-hp-212cc-pressure-washer-epa-62200.html
We are the largest pressure washer and floor cleaning equipment manufacture in the world, let me know if I can help
http://www.karcher.com/us/Home.htm
