Mechanical Diodes vs. Sprags vs. Spragless
41K views 15 replies 10 participants last post by  Hutch
Fricken retard here on the art of converter-guts...so no pokin fun!
Sorry if I missed it using the "Search" function........
I was told by Lenny at Ultimate that his 8" with mechanical-diode is the shiz converter for my all out - n/a setup.
Can you guys educated me on the benefits and negatives if any, on the mechanical diode setup...? How it acts in comparison to a Sprag'd setup, versus Spragless?..
Will MPH be compriable to a sprag'd converter with the strength benefits of a spragress design going with a mech. diode converter? I believe that's what I got outta the two brief conversations I had with Lenny.... but I could have misunderstood.
I am seriously considering this converter as I've spoken with many running Lennys 8" with Mech-Diode kickin ass with compriable setups...
Just really wanna learn the tech aspects of the different internals.
Greatly appreciate any input....
#2 ·
The diode is the Cadillac of the mechanical clutch assemblies used in a torque converter. Sprags , roller clutch's are the same just a different style.
Spragless converters have come a long way, are here to stay and have a place. Many have used them and seen very little difference in performance comparing them to a clutched stator but for all out performance in some applications a diodes, sprag etc. converter is preferred.
Hutch
#3 ·
Thanks Hutch.
#5 ·
That and it also reduce the tendency for the sprag to slip when in a stall state. It tend to give you the consistency of a spragless with the efficiency of a sprag. We ran them in several turbo cars and the results were positive. I have them put into all my street/strip converters to.
#6 ·
Good to hear, thanks guys. I will definitely be getting one, just gotta save the buck$ right now. Will run my Hughes ProVI Spragless 9" to start the season.. then make the swap hopefully in a couple months. Curious to see the difference. Thanks again.
#11 ·
Shweet!!!! Exactly what I was looking for. Great Info! Thanks Steve!
How you doin' up there? ;)
..and thanks JMark for the pics...
#14 ·
I have seen alot of guys go with aftermarket pumps and stator supports. Granted the diode does apply more stress on the support, the application and driving habits have a lot to do with longetivity. I have seen stock supports hang in there in some applications, but an upgrade is always a good way to be safe. A lot of good input here guys.
