LS Coil output voltage
24K views 32 replies 15 participants last post by  para pay
Does anyone know what the factory LS coils are rated for output voltage? I've not been able to locate anything concrete that says what the output voltage is.
Thanks!
#3 ·
A little. We're trying to figure out if we're at the limit of the stock coil for the gap/boost we're trying to run.
When looking around, it seems that every aftermarket company says their coils are rated for 40kV +/-. However, the MSD coils have been proven to show no gain. So...are the factory coils putting out 40kV, too?
#5 ·
We haven't messed with the dwell. To be honest, I think when we choose the LS ignition in the Holley we're not able to alter the dwell. I'll have to check. I do know, though, that it defaults the dwell to 5ms.
We do have the round coils and we may just be at the limit of what they can do. We're going to tighten the gap and give it another shot tomorrow.
#9 ·
What gap and boost?? Wide gaps only cause problems and make no more power. Top Fuel cars make 10,000hp running .014" gap so unless you are doing something that is beyond the coils output .014-.018 will work. Voltage is not where the gains from spark power come from, current output and length of spark event is what makes the difference. Hope this helps.
#12 ·
What plug and fuel??
#15 ·
Be careful with dwell time on the heat sink coils as they can autofire over 4.5ms at high RPM. How much power you can make will depend on chamber design and controller capability to fire the coils. On the square truck coils we could run 32psi and go 204mph to the 1/4 and no faster. The Mercury Marine style coils would not get us much further. This could be because of our small "fast" chamber or the BS3 controller. We ran up to 7ms of dwell at 8000rpm on both. We then put a MAG on the car and went from a best of 6.8x@204 to 6.5@223 in just three passes in one test and tune night.
#16 ·
THE PRO MAG 44 HAS NO EQUAL, no matter how many coils per cylinder you put on it. I would have never believed the difference it made but seeing is believing.
