I converted a 2002 pace 44' living quarters trailer from screwed to taped, it was a lot of work but well worth it. Like quoted above, you need to prep it correctly or don't even bother. I spoke with 3M techs quite a bit before deciding to do it, also there are quite a few videos and text online to get a good idea on how to do it. The hardest part for me though was the stringers that you attach panels to on my particular trailer were not originally painted and totally rusty, which took a lot of time to repair before even starting.
I learned a lot of 'tricks' on the way to installing the panels, one of the most important was using narrowed strips of duct tape (about 3' lengths of 1/2 width, then folded over pieces of duct tape) on the top of each of the 3M taped stringers to be able to pull the plastic 'protect' strips off the tape 'after' you set the panels in place. There is no way to just pull the plastic protect strips off first and just slap the panels in place .... it is just not gonna work consistantly.
If this 3M tape was good enouch to hold the heat tiles on the front of the space shuttle, it will definately hold aluminum panels on at 75 mph . There are other manufacturers of this type tape, but the 3M is definately the best, it is kinda hard to purchase if you are not a manufacturer of trailers etc, as I imagine they don't want laymen trying to use it and not being diligent on the way they prep and having crappy results from poor prep. I would imagine the couple of stories i hear about the tape panels coming loose are from some of the factories not prepping correctly (some of the videos i saw looked like that could be the case in some of the production shops).
One of the other main things to consider is your panels are now made to 'float' and not be constrained by binding them up by using any screws that will not let panels give a little. There are 2 different thickness of the tapes to use. thin for the end of the panels where they attach to next panel (.045) and then thicker .065 for attaching to the stringers.
It took me about 4 weeks of night times after work and weekends to do mine, but i also fabricated and widened my side door from 36 inches to 50 inches so i could load a golf cart in the side door during the repaneling.
I may down load a lot of pics on a hosting site of the proccess as pics are a lot easier to explain than just telling how to do it, as soon as i get a chance.
Randy
