Im trying to take advantage of the cold weather lately and get cold starts under control. But Im having a problem with the engine wanting to die if you fire the engine up and touch the throttle. Ive found the reason why it does it but cant seem to find a solution.
Im using a DBW throttle body, the "hard stop" is set at 11.2% in the pedal vs blade setting. Its runs and drives perfect (800rpm idle) when the engine is up over 130* but when the engine is cold the high idle is commanded to 1100rpm (15% throttle is the result). If you touch the throttle it goes right to the 11.2% hard stop and dies, or surges badly.
If you start the engine and let it run until warmed without touching the throttle it wont mess up. Only if you touch the throttle. Anyway to fix this??? its a minor thing but Im picky and want OE like driveability in all conditions
I can post a log if needed
