Well you have to be carefull. Because alot of people buy a pump, then later have to send it back to get it upgraded, or more flow added. So depending on the markings, it could be a 0, or a 01/2, 1,2 etc... Go to killerrons.com and read his section about buying used setups. In my opinion its alot of true facts. Not a way of telling you you shouldnt have bought it. James is real good with these setups, you might just want to send him your stuff. And pay him a few bucks to check it out and give you a good baseline, based on your fuel pump, barrell valve etc... The toilet setup is pretty easy to get a handle on, But if you have the wrong parts, it could be easy to get lost, and ruin some parts. Also have him explain the operation of how the system works, with the cable shutoff lean out. I see so many guys idleing at full fuel, and then wonder why they make no heat. And wonder why there oil is milky. Good luck to ya.
