How hard is the job and can the u joints be replaced without removing the shaft from the outdrive?
Gimbal bearing is not easy to replace but when you do please do it right and install the notched part of the carrier of the bearing facing back so next time you don,t need to replace the whole thing and just replace the bearing by hand turning it 90 degrees to let it slip out tru the notches, and yes you need to remove the drive to replace the u joints!
By the way if you take it to a Mercruiser shop they will install the gimbal bearing carrier backwards again to make money again out of you the next time and trust me is not cheap.
Also you will need the HD (heavy duty) U-Joints.. You do not have to remove the spanner nut and pull the carrier out if you have the right C clamp press.. I have done them on the drive with a Piston wrist pin...
I would check the cone cluches while I had it off , if it were me...
