front fender exit exhaust on Foxbody....lets see them..
1 reading
72K views 54 replies 30 participants last post by  Farmer2323
gonna go with a front fender exit exhaust directly off my turbo using 4 inch piping.....would like to see everyones setup and maybe some info on how its routed
thanks
Trevor
#5 ·
Not a fox body and not quite fender exit. I was going to exit out the fender/front bumper but decided to keep it more sleeper and dump near the passenger front tire. It has a 4" electric cutout that can be opened to dump to atmosphere or if closed exhaust goes through stock exhaust.
#14 ·
There was one on here. Fox body with a SBC and it went up thru back at the cowl. Some people say it will burn the paint off the roof right above the windshield
#24 ·
i wouldnt do wastegate out of aluminum just because of the heat pre turbo that will come out there. down pipe is different as its not as hot afterwards
#33 · (Edited)
Is that a 5" DP?
Also, How is the turbo mounted? Is the frame rail supporting it?
Thanks, Casey
#36 ·
I've had it a couple ways.
Thru the hood
Mini bull horn (with optional bumper caving, before support, LOL)
Most recent 6" aluminum (in the search to make sure I had no downpipe restrictions) Little overkill
