Fresh build with brand new carburetor. I'm new to carbs.
Quick fuel 750
Annular boosters
Electric choke
Other info
Manual trans
Hyd roller cam
What order do I attempt to set everything and what to look out for? Would rather not chase my tail while trying to get timing set and get rings seated, etc. I have o2 sensors in the collectors of each long tube.
Here's what I think I understand
Get fast idle adjusted
Set choke to show decent afr
After a few minutes get it off fast idle
Set idle speed
Adjust idle mixture screws for best vacuum
Adjust idle speed if necessary while adjusting mixture screws
Go drive it to seat the rings.
One of my other questions would be, let's say I go drive and it starts to overheat, or I have other issues, how bad is shutting it down before rings are seated?
Quick fuel 750
Annular boosters
Electric choke
Other info
Manual trans
Hyd roller cam
Set idle speed
