I have a set of doors that were stripped to bare metal then primed with an etching primer then a 2k urethane primer. Can body filler be applied over the 2K or should I strip those areas back to bare metal?
you can put mud over 2k primer but if u want it as right as it can be strip the doors put 2 goats of epoxy on the doors let dry over night then do your mud work over the epoxy... this is a lot of work... depending your skill level.. this is much harder because you are now dealing with 2 substrates.. intead of just bare steel......Paint by krusty 1 970 405 6373
the problem with doing it this way is that when you put your mud over anything ..but bare steel.. when you knock your mud down with anything coarser than 150 you will scratch your substrate ....then when you get your mud work done ..prime it, block it, paint it, when all that crap eventually dries you will see those little scratches out on the ends
if anyone tells you different they are lying to you...if you want it as nice as possible just strip the door...it takes about 10 minutes to strip just about any panel if you know what you are doing...pm me if you want more in fo....Krusty
see my sticky at the top on how to prep bare metal, thats the route i stick to in all my paint work. after using dp epoxy i like to lay down a coat or 2 of high build with guide coat and block that out to see what low spots i got to deal with before doing any filler work.That is unless i allready know then its right over the dp,then once all body work is complete the final coat before base coat i like to block with 400-600 grit.If you do any filler work, there must be at least 2 coats of prime to keep from getting fathered edges around your body work/filler.The dp mixed as a sealer would help here or you can reduce k-36/high build primer and use it as a tintable sealer.Jeff, What etch primer are are using? Your putting it down first & then putting bodyfiller on top correct? I'm not aware of any etch primer that this works well with.
Opinions on the "correct" methods of autobody work is probably more varying than what different engine builders feel is the right bearing clearance.
I really think "which way is better" in this case comes down to the skill & knowledge of the person doing the spreading & sanding. I agree with Krusty that it is likely that the doors will show some sand scratches, however I also believe that Fontaine has & can do filler work over the 2k primmer & not have any problems. The trick is knowing when & where to stop sanding with what grit & also what materials work better in such a case. I personally have done it both ways with good pretty results either way. Have I seen & have made some "scribble" (I call it) out at the edge of the filler spot at some time...yes, once in a while, but minor. These are chemicals, they can change "habits" with different weather, application & substrates & top coats. With a lesser experienced person, the likelyhood that the scratches show, goes up. So I agree with both of you to a point, EXCEPT the lier part!
As to "What to do?" My thought would be...How big of a spot, how many spots, are we talking about? If it's a missed ding or Two or a little damage from rough handling since the primer job, I would sand the primer & swipe. If we are talking...The doors were striped & primed, fully knowing it was just to keep them from rusting & they need several applictions of heavy filler & sanding &/or a large portion of the door needs covered, I would strip it. There, Now one more opinion added to the mix. Lorne
