I have a 4.3 v6 turbo syclone. Redlines at 4500rpm. It makes 20psi of boost at 2300rpm. Where should the timing be when that low rpm? I had 18 degrees and went to 20 degrees and it seemed to clean it up. With lower timing it would misfire it seems when the boost would come in and clean up once it got up in the rpm.I have 24 degrees in it at 4500rpm/20psi and the plugs look happy. This is also on e85 and stock turbo. Any help is appreciated. Compression is 9.5:1.
