I'm building up a datsun 280z with a toyota 185 ci 2JZ. I'm going to be running a TH400 transmission behind this for starters. My current setup should make ~1200FWHP at full tilt. I may upgrade the turbo in the future to a GT5591 which would get me in the 1500+FWHP range. The target weight for this car is ~2500lbs with driver. The factory wheelbase is 90.7".
Anyway, I'm really struggling with making a decision on what rear suspension and drivetrain to put in this car. Part of me wants to stay with a factory like independent rear suspension and see how far I can take that. This will limit me to running a 28" diameter tire. I was thinking that I'd run a 28X11.5" MT slick if I do stay with IRS.
If I do go to a solid rear axle, I will do a 4 link setup. I would move the rear wheels back 1"-2" to lengthen the wheel base if I do 4 link it. The factory rear track width is 53". What would be a good rear end to go with that will handle my potential 1500hp in the future? What size tires would you guys recommend for this setup? I would like to stay away from wheelie bars. This is a short wheel base so I'd imagine I'd have to limit traction to accomplish this. I wouldn't mine running a 325/50-15 or smaller radial to accomplish this.
Just trying to figure all this out as this is my first buildup of this level.
Regards,
Justin
Regards,
Justin
