Im needing to cut my rear fender lips for some tire clearance,Does anybody have any pictures of what they did???? prob cut from 10-2:00
Its been rolled, but with new wider rims I need to cut/trim them, Car is already painted. Dont think the bat will push/bend it out enough. Im thinking if I go to far the inner well will separate from the outer and turn into a ordeal. Like most Chevelles one side is closer than the other.
Thanks for any help
Rob
The MT slick is 29.5x10.5 and it clears fine,The 2 drag radials I have 316 and 325 has wider tread making the sidewall come out further, the drag radial is 1/4 wider on section width,13 1/4
Thanks for any help
Rob
