I can say its for sure not a tenth in our cars, per hundred pounds. But I am curious what some of the other teams say. The reason for this here is what I am looking at.
RVW WEIGHT SPLITS....
SB N/A NO WEIGHT
BB N/A 2100 LBS
SB NOS 2200 LBS
BB NOS 2400 4.840 BORE ENGINES
BB NOS 2525 LBS 5.00 BORE ENGINES
BB NOS 2600 LBS OVER 5.0 BORE ENGINES
-100# FOR BB CONVENTIONAL HEADS
SB SINGLE TURBO 2600 LBS
SB TWIN TURBO 2700 LBS
SB TWIN TURBO (500 CU IN +) 2900LBS
SB PROCHARGER 2600 LBS
BB PROCHARGER 2900 LBS
BB TWIN TURBO 3150 LBS
BB TWIN TURBO (Non 481x / Non Hemi, 550 cu. in. or less) 3000 LBS
BB TWIN SUPERCHARGER 2950 LBS
BB Single Turbo 2700 LBS
4 cyl. and 6 cyl. combos 2500 LBS (Production Engines Only)
ROOTS BLOWER 2675 LBS
BB SCREW 3000 LBS
Now the new rules for LDR.
Nitrous
- SB Nitrous: 2,300 lbs.
- BB Nitrous (4.840/4.900): 2,600 lbs. (Max 10.3 Deck Height)
- BB Nitrous (5.000): 2,800 lbs. (10.4-11.0 Deck, Stock Bore Space)
- BB Nitrous (5.200/5.300) - 2,950 lbs.
Turbocharger
- SB Single Turbo: 2,800 lbs.
- SB Twin Turbos (Pro Mod 88s, Max): 2,950 lbs.
- BB Single Turbo (118mm Max w/ Conventional Heads): 3,100 lbs.
- BB Single Turbo (118mm Max w/ Non-Conventional Heads): 3,150 lbs.
- BB Twin Turbos (Pro Mod 88s Max, Cast Block HEMI/481X): 3,300 lbs.
Supercharger
- SB Single Centrifugal or Roots Blower (14-71 Max): 2,900 lbs.
- BB Single Centrifugal (F3-139/Roots 14-71 Max w/ Conventional Heads): 3,100 lbs.
- BB Single Centrifugal (F3-139/Roots 14-71 Max w/ Non-Conventional Heads): 3,150 lbs.
- BB Twin Centrifugal (F2 Max w/ Conventional Heads): 3,250 lbs.
- BB Twin Centrifugal (F2 Max w/ Non-Conventional Heads): 3,300 lbs.
Weight Additions/Deductions
- MT Pro 275 Tire: 50 lb. Weight Deduction
- MT Pro 315 Tire: 50 lb. Weight Addition
- SB Non-Stock Bore Space Entries Permitted with 100 lb. Weight Addition
- Billet HEMI or 481X Engine, Add 100 lbs. Over BB Twin Turbo Combination
It took years to get people to understand the 14/71 roots is no where near as efficient as the procharger or turbo stuff, and we are going to support this new class, and they have said they would adjust the rules if needed, we would just like to be in the hunt to begin with. I feel our combo is 100 lbs heavy in base weight at a min... Yes its a HEMI, yes its a bad ass piece but so are the others in the class, just looking for some outside eyes.
