Cam specs in your engine ?Same short block and cam with my PC heads and ported Edelbrock 2829
Jon,Cam specs in your engine ?
So just how much is the right cam worth? You don't need to answer. We will all find out with real dyno results in a couple of weeks.1 or 2 points of comp is not 70 ft lbs difference. Not even half that. You can't spin or polish that turd .
I'm sure Eric's engine will run much better with a proper camshaft.
They said they were using Powell cam for base. They don't even know what cam is in it ?That's an 8,000 rpm cam. 284-298 @. 050 .... Not the correct cam for this engine at all.
I think it's going to get stomped on by some small cams.
With one of the cams in the competition 1.35 lbs ft per cube is a reasonable target = 576 lbs ft.
There should be a few that pull that off or better.
Thanks ... It wouldn't load on my phone for some reason.The cam specs are on the dyno header.
It's not.They said they were using Powell cam for base. They don't even know what cam is in it ?
That engine will produce some good numbers with the right cam. That's not the right cam. Of the 16 cams it's 10* more duration than the next biggest.1 or 2 points of comp is not 70 ft lbs difference. Not even half that. You can't spin or polish that turd .
He knows exactly what cam is in it. Are you just too lazy to watch the video ?Thanx bbf 612 and 600" for clarification. We won't degree the cam and we ain't even sure what cam we left in it, but we will give you the results. Oh the life of YouTube engine building. Lmfao!
Not Knutz. Same dyno who/that did the LS.Eric explained that in the video, I think Knutz was checking valve to piston clearance with that cam and forgot to install the Powell cam.
Too be honest, I saw the one were Eric said he was putting Powell cam in to baseline. I don't watch everything he flaps his gums about nor do I read every sentence written on here. I'm not a you tube engine builder and I have to get the right parts in the engines I work on. I don't have every waking min to bounce the inet and keep up with it.He knows exactly what cam is in it. Are you just too lazy to watch the video ?
It's not the cam Eric was expecting to run when he got to the dyno. Sometimes shit just doesn't go as planned. That's what happened here.
One of the cams, of the 16 in the competition, was run in the engine. There are 16 cams to pick, and 12-15 of them will be the Right One. The one with the most intake duration, by 10*, was not and is not the right one.Too be honest, I saw the one were Eric said he was putting Powell cam in to baseline. I don't watch everything he flaps his gums about nor do I read every sentence written on here. I'm not a you tube engine builder and I have to get the right parts in the engines I work on. I don't have every waking min to bounce the inet and keep up with it.
Jon,Not Knutz. Same dyno who/that did the LS.
