cal-tracs vs slapper bars F100 truck
6.1K views 17 replies 8 participants last post by  droppedf100
Are people seeing a definite improvement hooking consistently when going to cal-tracs? Im especially concerned with drag radials. Its for a 79 f100 shortbed 4100lbs with dropped I beams up front and cheap 90/10s and a flip in the back (rear on top of springs) with slapper bars custom made right at the spring eye and Rancho 9000s mounted straight up behind the rear. Its a bbf that made 455 to the wheels and a 175 shot on top of that with a c6 3500 coan converter. It will hook on a 28x10.5 1.49 60ft but I want to get it going with radials. It spins delaying 3 tenths with a digiset.
#16 ·
Justrunit, do you have a flip-kit on the rear of your truck ? Doesn't look super low... looks like it sits like mine... I just have the Shackle extender and the Bracket up front... without flipping the axle... about 4 inches of drop
I have been wondering if flipping the Axle or keeping it in the stock location makes any difference with the Cal-Tracs
#15 ·
Thanks Bowtieoverdrive.com has several on there site and you can search for Justrunit on youtube several on there. We was picked 2007/2008 Hot Rod pump gas drags also she run 10.40 @ 128 at memphis with a 1.58 60 ft time you do the math. It went 6.40 at Hub city back in December but just run 10.3 quarter mile four runs on that bottle.
#9 ·
What does your front suspension consist of? I have over 5" of travel in the front. I plan on ordering the bars in the next couple weeks.
It hooked on a 28x10.5 slick with a 200 shot right out of the hole with my old set-up. I have to delay the nitrous now and it still spins on the radials with 175hp. Best 60ft 1.55. Never got a chance to run the slicks with the current motor. Im hoping for consistent 1.4s. I eventually want to hit the 9s with i-beams/leaf springs with a bigger motor.
#6 ·
I have been high 9s... best ever with 75mph tail wind is 1.50 flat... BUT ... After looking threw this site i have learned alot and looking forward fixing that !!.. there are alot more adjustments with the caltraxs .. they are a very good product for the money and alot more ground clearnace ... when slapper bars... Also.. a huge mistake i made... if you have trouble hooking it on a slick there is no way in hell its going to hook on a DR....get it close on a Slick then make the switch...
#5 ·
I'm not a hardcore racer or anything. But I did go from slapper bars to caltracs and I noticed a definate improvement in the way the truck feels on the launch. I haven't had it back to the real track(our local track don't have 60ft times) with the caltracs, but I can tell you that it can take a harder launch without breaking the tires loose at our local track which is just an airstrip.
#3 ·
The nitrous hits alot harder out of the gate than a turbo so that isn't a fair comparison. How fast have you been?
Nobody on here has ever gone from slappers to cal-tracs? I figured this was a popular transition. Just want to make sure they will help me with what I am trying to accomplish.
