Is anyone controlling boost with procharger? Like running 2 bov and bleeding off boost? Is their a right way to do this or does it shock the procharger
did you even read what you wrote? is completely ass-backward to what you are trying to imply.Open to atmosphere at the lowest PR is the the highest load and hence the lowest RPM achieved
As you start blocking off the outlet and raising the pressure ratio the impeller speeds up from less load
You are so full of shit it isn't even funny. If you partially block off the exit the load goes up and the engine or motor will slow down> yes I tried it to see who was full of shit.
