Blow thru for NA motor
1 reading
9K views 9 replies 6 participants last post by  prostreet68
Searching for information to make sure this is true. I was told that a blow thru carb can be used on a NA motor. I am not sure and wanted to verify what I was told. If it is true then I wont have to spend money on a NA then spend money again on a blow thru when I turbo the car when money allows.
#4 ·
I ran a CSU blow throu carb. It will run very fat N/A and under a load will kill the motor with fuel. It will still run, but definetly not very efficient IMO. You will have to make changes in order to drive it N/A and if your looking to maximize your N/A deal then its definetly the wrong way to go. It all depends on what the blow through carb was built for.
#5 ·
I did talk to Kevin@CSU and he did say that he would take into consideration that it was being used as a NA. Being on such a tight budget just to hear this car run after a 3.5 year build I decided to do a NA motor then save up and do a nice turbo motor when money permits.
I had been looking for a HP holley at a good price and then send it on down to Kevin. I may need to just buy a nice built carb(750) and then worry about the blow thru later.
Any suggestion????
Thank you
#9 ·
Any suggestion????
Thank you
I think you answered your own question. Sounds like the best way to go to me. 750 now and convert or sell it later to go blow through.
#7 ·
The carb will not function on an n/a engine if it's designed for blow thru. I've tried to run Filipowski's engine without the carb hat and part throttle/idle is fine but when you tip into the throttle hard it gets real, upset. What exactly it was doing, I didn't really care it's not an n/a engine.
#8 ·
The carb is calibrated to move a higher amount of fuel at X signal. Hard to explain, but you would not take a alky carb designed to move twice as much fuel and put it on a gas engine and it run good.
#10 ·
Ya ...the more I think about it that may be the correct way to do it. I guess now I need to decide what carb I need to run.
This car is a weekend car that will see the track a few times but basically a weekend play toy. Here is Ca. I wouldnt need a choke but I do want a real crisp throttle.
Need suggestions please...
