ok my setup is a 73 meverick grabber ,mild 460 ,c6 suto, 3.00 gear, s475 turbo. to be more specific it is 8.5:1 compression, home ported d3ve heads with stock valves, edelbrock cheapo springs, edelbrock torker2 intake , .503 lift 276/286 adv. duration 114 lsa cam , .030 overbore 466, 2500 stall dacco converter with anti balloon plates, the carb is a carb shop 950 cfm i think it has 75 primary jets 90 secodaries , the front power valve restrictions are .057 and the power valve is a 6.5 the back one is blocked, tiny high speed air bleeds , and bigger idle air bleeds i dont have any drill bits here small enogh to measure them. i bought the carb used so i dont know what if anything has been changed on it i have only changed jet sizes .
here is the problems first it wont idle any leaner that mid 13's a/f without starting to stumble and die i dont know why it wont idle in the high 14's ?
secondly driving slow is pig rich when you are driving and let off the throttle it goes into the low 11's a/f , when you go 1/4 throttle driving it is still in the high 11's , then driving at 1/2 throttle it to 3/4 throttle it go's anywhere from 14's a/f up to as high as 16-17 and backfires lean .
thirdly at wide open throttle on 15 psi and pump gas it is staying in the high 13's a/f i would like it to be at least in the low 12's
i was going to try and block the high speed air bleeds someone told me that might richen it at WOT , also though about putting extensions on the bowl vents i have heard that can fix WOT also but i would really like to get it leaner at slow cruising but i am not sure what i need to do
any help would be greatly apreciated i am running 93 octane with 36 degree's of total timing pulling back to 15 degree's at 15psi boost
it has ran a best so far of 7.30 @100mph in the 1/8 mile with a 1.75 60 ft but it was slipping my old converter 30-40% hopefully that is fixed now
